RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Posted on Apr 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CP150 Capacitor Replacement
Hi
I have a RCA D52W20 and have read about the trouble with it not turning on. I have the same problem, green light comes on 3 times but it won't turn on. I just took the back panel off and located the CP150 capacitor (thanks for the guidance before). It is puffed on the top and had some residue on the top as well, so I would suspect that is the problem. My question is to make sure the steps I take from here. I can go to Radio Shack and get a new cap, but I am no solder expert. Luckily for me, where I work has an electronics lab, so I can take the board in and get the new cap soldered on. Do I just unplug all of the connections, pull back the tabs that hold the board in, and remove the board? Is there anything I need to be careful to do or not to do? I plan to take a few pictures before removing the board and label the connectors/cables, so I can plug them back in correctly. Once the cap is replaced, I just put the board back in and replug in all the cables/connectors - then I am good to go (unless other issues exist, of course)? I appreciate any help, I just want to make sure I do this correctly, to get the TV fixed but also to make sure I don't mess something up.
Thanks.
  • Hokie 91 Apr 25, 2008
    Thank you for the advice. I acutally just finished replacing the cap on the board. I was not able to take the board into the lab at work, but borrowed a solder iron and brought it home with me tonight. I haven't soldered anything in the last 20 years, but a buddy at work gave me a 5 minute course on it. The first time I soldered the cap on, I didn't get a good connection and the TV would not turn on. So I read again on good solder techniques on the web, took the board out and soldered the cap on again. This time the connection looked like the others on the board, so I thought I had a good chance. I put the board back in, plugged in all of the connectors and the TV turns on just fine. I have only tried it on and off 3 times so far, but it has worked every time. So we'll have to see how it goes, but it is working for now.
    Thanks.
  • j P
    j P Feb 05, 2018
    whats the part info for that capacitor ?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 319 Answers
  • Posted on Apr 23, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
319
Questions
0
Helped
116026
Points
503
The swollen electrolytic cap dose indicate defect but, also may mean a run-away voltage from an open zener diode or shorted regulator which regulates voltage. With luck, replacing the cap may do it, but may not complete the needed remedy. If you are not proficient with soldering or PC board work, I would strongly suggest taking unit to qualified service for complete analysis and repair
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1135
Points
My 27 inch GE(model # 1917787/27G7618) regular TV works well. However, occasionally the screen narrows to a thin line in the middle and the tv will not turn back on for at least an hour. Any suggestions or comments? thanks
A
Anonymous
1helpful
Trouble turning on
Thats a easy and inexspensive repair. You can get the RCA repair kit called CP150, CP120 and CP114 capacitor repair kit from www.tvrepairworld.com which also has the cd with detailed instructions.
1helpful
I have a D52W20 green light comes on 3 times but has no power.
Replace capacitors in power supply area
Replace capacitor cp150 (2200mf 16v ) capacitor CP120 and capacitor cp112
Replace this capacitor too: CP114 (330uf @ 35V )
Thank you
3helpful
Tv wont turn on, RCA D56w20, 56" rear prjection
replace the flyback 259296 and the CP150 capacitor. You can get the replacement parts with free instructions at the following link.
http://servicemanuals.vstore.ca/
2answers
Television will not turn on
ON the Deflection board look at cp150 (2200uf 16v)- if it is puffed up on top it is bad replace it and 2 more cp114 & cp120- 220uf 35v. Radio Shack should have capacitors. they are green with gold writing on them.
HAPPY NEW YEAR!
Rca projection tv
Capacitor on Deflection board cp150 2200uf 16v if it is puffed up on top it is bad 2 more caps cp114 cp120 220uf 35v replace them if cp150 is bad.they are green with gold writing on them.
52 inch RCA
No, check cp150 capacitor 2200uf 16v if bubbled up on top it is bad ,you have 2 more caps to replace in same circuit if cp150 is bad cp114/ 220uf 35v -cp120/ 22ouf 35v they green with gold writing on them
Rca d52w20 52 IN
Bad capacitors on Power/deflection board cp150,cp114,cp120 capacitor cp 150 2200uf 16v, cp114&cp120 220uf 35v
My tv will not turn on RCA45 inch tv model D52W20B
The flyback is going out and the CP150 capacitor is almost certainly failing as well. You can get the replacement Flyback number 259296 and the CP150 Capacitor at the following link and they provide step by step instructions with pictures so you can easially do the repair yourself. Here's the link.
8helpful
3answers
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
3helpful
2answers
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
