Beverage-Air Beverage Air KR48-IAS 44.9 Bottom Mount Refrigerator Logo
Posted on Jul 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to see if evap fans r working
I need a wiring diagram for the beverage air freezer model kf48 1as so i can diag the problem of fans not coming on took apart evap cooler to find out my epantion valve was bad now my fans not starting up
Dennis Boxerman
Level 3:
  • Beverage-Air Master 1,306 Answers
  • Posted on Jul 11, 2010
Dennis Boxerman
Beverage-Air Master
Level 3:
Answers
1306
Questions
Helped
646818
Points
2787
Http://www.beverage-air.com/uploadedFiles/docs/CFG_CRG_KF_Series809-046A.pdf
this site has your manual and the manual has wiring diagram.
also has some common trouble shooting questions and answers.
1helpful
Fridge freezer not working and fridge interior light comes on but is very dim
There is an Evaporater fan located in the back section of your freezer and depending on year of the fridge supllies the air flow to the freezer and fridge section and may use a circuit board or may not. On Fridges newer than 2002 they use cuircit boards prior years do not. The power to the evap fane is shared with the light in your freezer and a locked up fan can cause no cooling and draw too much amperage and cuase the light to be dim. My suggestion before trying to diag is go to www.aplliancepartspros.com and look up your fridge by model number and locate the diagrams for the freezer section and you will have a better idea what you dealing with.
1helpful
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Evap fans will not run what are the two sinsors ?
First, the freezer coils have a temperature sensor strapped to it with a copper band.
The fans won't come on until the coil is under 10 degrees. Second, the fans won't come on if the doors are open. The same switch that shuts off the insdie light also turns off the fans. Try those two items. If the coils never get cold enough the fans simplhy won't come on at all. You may have low refrigerant or the other coils out by the compresor may be clogged with dust or grease.
1helpful
Evap fan will not come on,jumped out the fan control fan comes on
Since this is a freezer, it should have a defrost terminator/ fan delay. This could have gone bad or you may have a refrigeration problem. Such as low on freon due to a leak. Need more info, I'll explain in detail. Let me know. Will Be more than happy to.
1helpful
4answers
Beverage air model UR30G, not cold, fan still running
check the thermostat for proper setting, evap could be frozen up, the condenser fan could not be running, unit could be low on freon. start check some items and let me know.
2answers
Unit not freezing , evaporator fan wont run
If this is a Bev-Air, don't think the door switch will control the fan. At the evap, there is a temp sensor called a fan delay. When unit goes into defrost mode, this warms up. Some also serve a dual purpose. It will terminate the defrost cycle at a certain temp., say 51 degrees or so, at the evap. Anyway, when unit comes out of defrost, it keeps the fan off so it allows the evap to cool quicker and to prevent circulating warm air. This could be your problem. Not a hard fix but they can be a pain sometimes. Outside chance that the unit is low on refrigerant (freon). This will not let the evap get cold enough to trip the sensor back into position to turn the fan on. Good Luck. Restaurant Parts and More carry alot of Bev-Air stuff. 1-888-814-1110. Ask for Rick
Freezer cold/Not Cold in Frig KITCHENAID Model KBLC36MHS01
I couldnt find a diagram of this frig.
Some of the evap. fans run thu the defrost thermost ..u could try by-passing thermost and see if fan comes on...  have you checked with volt meter if there was power at the fan motor?
Top Beverage-Air Refrigerators Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
