Motorola Mobility RAZR V3 Logo
Posted on Jul 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
Anonymous
Level 3:
Genius:
  • Master 1,478 Answers
  • Posted on Jul 06, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1478
Questions
0
Helped
287776
Points
4140
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
1helpful
Bantum rocam 1.6 not charging battery. the no charging warning light does`nt show any mulfanction. is there any fuse or relay related to battery charching ?
removing the battery lead when running is a very good way of blowing the rectifier pack, voltage regulator or line diode
take it in for a charging system check to see what was done wrong
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
My sms dongle says it's charging or charched.. but wont turn on after I unplug it from the charger
Replace the battery, or make certain the charger is charging. Does the dongle get excessively warm or hot
May 06, 2015 • Cell Phones
Battery charge
As far as "the battery is getting fat", probably from excess internal pressure, most likely from over charging.
Your voltage regulator is probably going out/already gone.
How do you charge your wii console
The Nintendo Wii is an innovative video game system and much like other video game systems within the Wii's generation, the controllers are all wireless. Because of the wireless technology, the controls must function on batteries in order to operate. Instead of having the game pause in the middle of the action, there are plenty of methods you can test to make sure your Wii remotes are fully charged.
instructions:
  • Charge you're the batteries to your Wii remote by opening the back clip and pulling out both AA batteries. If the batteries are the standard set that came with the Wii, you should upgrade them to rechargeable batteries to save time, money, and garbage waste.
  • 2
    Let the batteries charge for as long as the charger says. In most cases a full charge could take 6 to 12 hours, but fast chargers can fully charge batteries for an hour. Check the charger's manual detailed times.
  • 3
    Use a Wii Charging station for easier charging access. These stations avoid the process of opening and closing the Wii remote every time you need to charge the batteries and they work as a Wii remote stand as well.
  • 4
    Place the batteries back into the Wii remote once the charging has completed. With both the charging stations and rechargeable batteries, lights should indicate when the charging has completed.
  • 5
    Power up the Wii and press any button on the Wii Remote in order to turn it on and connect with the Wii.
  • 6
    Press the "Home" button the Wii Remote control. This button is in the center of the controller and features a small picture of a house on it. A pop-up menu will appear over the screen.
  • 7
    Look at the menu and find your controller number. Right next to the assigned number is a remote battery meter. It will feature 1 through 3 bars to indicate battery level. If it has 3 bars, then the Wii remote is fully charged and ready for use. If it has any less bars then the remote can be used, but is not fully charged. If the battery meter is in red, the remote will shut off soon because there is not enough battery power.
  • 1helpful
    2answers
    Battery going flat early even after charging
    sounds like its either the battery is bad or its a defective phone very popular for the v3 razors
    2answers
    Charging new battery
    usually 8 hours.
    for first charge.
    on a brand new battery
    K1 Problem Charging Battery
    sounds like the battery to me. there is a chance it is the phone. Check on your warranty and see about a battery replacement first. Its much more likely.
    Top Motorola Mobility Cell Phones Experts
    AFIFUL HAQUE MUFTI...
    Level 1 Expert
    vince
    john h
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
