When changing the rear turn signal bulb, how do you get to the bulb?
Lower the tailgate and there is usually two screws holding the tail light into the body. Remove the screws and pull on the tail light, if it does not come out take a screw driver and gently try prying on the tail light. Make sure there are no more screws holding it. Once you have the tail light removed twist the socket out and remove the bulb. Go to the auto parts store buy bulb. Replace it in the reverse order but do not put your fingers on the glass of the bulb because they are halogen bulbs and you could damage the bulb.
In a lot of cases on modern motors i just remove the whole light ,its easier most of the time and this is a pick up so the chances are it sealed light and access can only be gained by removal
SOURCE: rear turn signal bulb on a 2001 Chevy Monte Carlo
Its Accessed Through The Trunk Pop It And There Will Be Either A Panel To Remove Or Carpeting Material To Move Aside And You'll See The Wiring Harness With The Light Twist And Pull To Get The Bulb You Want Out.
SOURCE: 1998 Cavalier rear turn signal doesn't work
The turn signal switches are known to go bad, try to use the turn signal switch and jiggle the lever after clicking to the left turn. Replace signal switch assembly.
SOURCE: Right Rear Turn Signal does not Work - Even after changing bulb
check ground wire to light unit....and inspect bulb socket for clean contacts.......
