What does an error code of c3852 mean on a Konica-minolta bizhub 350 copier?
C3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Good afternoon,
As I would like to help me with my printer problem Bizhub C-450 is appearing me the code-C3852 and I'm not to start.
thanks
I have a error code C-2555 I have a Bizhub-350. can someone help me?
Thank you
The ADF on my Minolta Konica bizhub C552 color copier will not feed paper and the orange light is flashing.
Hi! I have a problem with my konika bizhub 350. I was on the process of duplicating my documents when suddenly the next printout became blurry. My toner is new. I think I heard some sound on the right side of the copier. What should I do? Thanks!
The error technical code is C0520
what does this error mean
