Chances are that your reciever is outputting conventional NTSC .. not high def ... so you would scan for standard channels not hdtv .. if chanel selection is done by the satelite reciever then the scan will only find one channel 3 or 4 usually (or better yet you can use Svideo or component oututs if it has them .... if the receiver is a block converter that uses the tv to tune channels then you should get more channels detected ..
