I have a HP PSC 2400 Photosmart Printer. I tried to scan a document into a PowerPoint file and the scan seemed to freeze up. It appears to be stuck in the queue. I cannot get it to cancel or print. I have checked the queue and nothing is there to delete but the printer/ scanner still seems to be trying to do something (the green button continues to flash). How can I correct this problem and get my printer to working again? I have tried disconnecting the printer from the power source, waiting 30 seconds and reconnecting. I have tried restarting the computer. Still no good.
SOURCE: Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
SOURCE: Docs in queue won't cancel so I can print another document
turn of the printer and unlug the data cable.
go to start>>printer and faxes, open the printer queue and deleted the job.
plug in the data cable and turn on the printer
SOURCE: Can't cancel print file
hello, unplug your printer and restart your computer. turn your printer of and reconnect it to the computer when the computer have restarted. then turn on your printer and I think your queue should be empty.
SOURCE: I had my printer (hp psc 1200 series) try and
You need to go ahead and simply refresh a service known as "Print Spooler"
here's how you do it..
for Windows XP:
>> click on start
>> click on run
>> type in " services.msc " and hit enter
You will see a list of service names alphabetically arranged on the right hand side..
From there look for the service name "print spooler"
>> right click on it
>> click on stop
wait for 10 secs
>> right click on it again
>> click on start..
>> restart the computer..
>> you will find your document deleted :)
plz rate if you find it helpful. thank you
SOURCE: I can't delete a document in the queue for
remove usb cable from the printer then try to cancel it then after switch off your printer then after trying to cancel if problem occurs then u have remover your printer driver and reinstall it
Testimonial: "thank you very much "
