www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can... Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Hi. You have to clear that error from service mode Try to clear that error from service mode press additional function 2 and 8 together press additional function select copier select function select clear select ERR select ok. Unplug of the machine for 5 second and then turn it back on try to make some copies, if problem persists fixing heater is damaged and need to be replaced
If you get the Error code 0x6101beb on your printer, it's one of the common error occurs in Printer. In case this error is not fixed, it may lead your system slow or even it will crash the whole printer. Fixing the error code 0x6101beb manually is a difficult process so we suggest you can use any troubleshooting tools. In Some times, remove the cartridge from the printer and reinstall it, this will clear the error messages from your printer. Follow the given steps for troubleshooting the error code 0x6101beb,
1. Power on the printer and open the cartridge access door.
2. If the cartridge comes the position, power off the printer and disconnect the cables.
3. Remove the ink cartridge from the printer and leave it for 60 seconds.
4. Then again insert the ink cartridge in their respective slots.
5. Power it on and check if it clears the error.
Still, the error persists on your printer, better you can contact the printer experts through the toll-free number 1-800-386-3987 or 123.hp.com/oj4650.
Error Code E05 Canon MP258 may solve by the following steps. 1.Press Stop/Reset button for 5 seconds.2.After five seconds release the button.3.Now your printer will start its process and it is ready to use... thanks
