Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Logo
Anonymous Posted on Jun 21, 2010
Frigidaire Upright Freezer Digital Display Not Working
Frigidaire Model - GLFU2067FW4 upright freezer with digital display. Unit is 3 years old. No manual available. About a year ago, the alarm started beeping continuously. Freezer was operating at good temperature so wasn't sure why alarm was going off. Last week, we noticed water on the floor around freezer and it wasn't running. It was unplugged for about 4 hours, then once plugged back in it operated fine except now the display is not on. We cannot adjust the temperature and do not know what is going on inside the unit without the display working. Have checked around and can't find any info on this problem nor can we get a manual for this unit.
  • 1 more comment
  • Anonymous Jun 21, 2010
    Frigidaire Model - GLFU2067FW4 upright freezer with digital display. Unit is 3 years old. No manual available. About a year ago, the alarm started beeping continuously. Freezer was operating at good temperature so wasn't sure why alarm was going off. Last week, we noticed water on the floor around freezer and it wasn't running. It was unplugged for about 4 hours, then once plugged back in it operated fine except now the display is not on. We cannot adjust the temperature and do not know what is going on inside the unit without the display working. Have checked the manuals I have found for this unit, but none of them cover this specific issue.
  • Anonymous Jun 22, 2010
    I'd say that's about the best thing I can do at this point. I appreciate your help. Thank you.
Charles T Nevin
Level 3:
  • Master 4,070 Answers
  • Posted on Jun 21, 2010
Charles T Nevin
Master
Level 3:
Answers
4070
Questions
0
Helped
1087036
Points
13055
  • 1 more comment
    Doesn't seem to cover this particular issue in that manual. Freezer is working fine, but the tempt control/display is off so in essence we have no control over the temp. Startingwonder if it's a simple matter of the temp control being bad, but would rather get down to the actual cause short of just hanging parts on it til it works.
  • Charles T Nevin
    Charles T Nevin Jun 22, 2010
    You might want to try taking the display control off and inspect it for any burnt or swollen looking parts looking at the solid state circuity.
    If you don't see any problem put it back in and see if resetting it like that helps. I would replace the control if that doesn't help.
  • kandy L kelley
    kandy L kelley Mar 04, 2019
    how do you resent a display
Chris Huff
Level 3:
Top Expert:
  • Frigidaire Master 6,289 Answers
  • Posted on Mar 05, 2019
Chris Huff
Frigidaire Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017767
Points
74913
Sounds like display / control needs replacing
kandy L kelley
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 04, 2019
kandy L kelley
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3338
Points
If the light is on and got set on 7 went will the light go off
A
Anonymous
Cany you remove the display? If so then disconnect it and reconnect it. Does it reset?
Anonymous
Level 3:
President:
  • Master 1,561 Answers
Anonymous
Master
Level 3:
President:
Answers
1561
Questions
0
Helped
296316
Points
4482
I advice you check the the two links below to search for the manual of your unit because the manual will shed more light on what the problem is.
manualsonline.com
Or
manualnguide.com
Type any of the above the link on your web browser to search for the manual of your unit.
Take care.
2answers
I have a Frigidaire FFU17F5HWD upright. I noticed
Reset the circuit breaker. It too maybe a GFI circuit.
1helpful
3answers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
4helpful
My new frigidaire freezer the digital display on outside of door flashes off what to do?
Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
My upright frigidaire freezer is set on -1 degrees, but the display on the front indicates the temp is 8 degrees. It has gone as high as 11 degrees. Does this mean it is defrosting or is there another...
Hello swanee3669 - Have you trying measuring the temperature inside the unit to confirmed that it matches the display? If so, I recommend contacting a professional to accurately diagnose the unit since it sounds like it could possibly have a bad sealed, thermostat or control board.
I have a Frigidaire upright freezer model# ffu20f9gw3. The temperature alarm light is on. Cold air is blowing but the ice cream melted, and the hot dogs are still frozen and loaves of bread that i...
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
2helpful
My Fridgidaire freezer is flashing E9 , What does
http://www.frigidaire.com/manuals
go to this web site. It has lots of manuals. I found several for your unit. just enter you model number and it shows up with several choices.
Hope this is what you are looking for.
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
1helpful
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
