Hello, the F13 means "Dispenser Circuit Error", if the dispenser motor is not able to be driven to its proper position.
Check the following:
1. Check mechanical linkage from dispenser motor to the top of the dispenser.
2. Check wire harness connection to the dispenser motor and Central Control Unit and lastly
3. Check dispenser motor.
Thanks
what if the drive is working, I see the handle move between the four stages but then it kicks off.
My dispenser arm would continuously rotate while still attached to the linkage and eventually would give the f13 error. Solution: there was oxidation at the contact where the wiring harnesses make contact with the dispenser motor. Once I scraped away oxidation and put back together it worked again.
F13 is the fault code for dispenser circiut error check the wirring to the dispencer motor sometimes its just a broken wire
