Using 3g wireless Linksys Routers is best router you use for inter net connection,
For customers using the AT&T 3G MicroCell and a Linksys / Cisco router model WRT54G2 or equivalent, the following settings should be made to the router.
NOTE: Changing the broadband router / modem / gateway settings may cause other applications to stop working, and / or change the broadband router security settings for outbound data transmissions. Please see the router / modem / gateway instruction manual for more detailed information.
Procedure
1.Open Internet Explorer and navigate to the router setup page at http://192.168.1.1
2.Enter the User name and Password, click OK
3.Verify the following settings:
Automatic Configuration - DHCP MTU: Auto Size: 1492
4.Select the Security tab, verify IPSec Pass through is set to Enable
5.Click Save Settings
I Hope Your Router Linksys Routers Problem Is resolved By now:
In case you need online Linksys Routers help then follow us on for:
This Gateway desktop does not have a wireless (WiFi) adapter. You can check out the specs on this WEB site. http://us.gateway.com/gw/en/US/content/model/DT.GDYAA.002
SETTING UP A BROADBAND CONNECTION First you need to decide what type of broadband and Internet service you require and these are - 1. DSL that uses your existing telephone line. 2. Cable that uses a cable service and can include a cable TV service. 3. A USB wireless adapter uses the same 3G mobile/cell phone network and can be separately or combine with your cell phone account. This type of Internet connection uses a wireless device shaped like an USB memory stick. Note - Combined services generally offer discount pricing and may include a modem/wireless router.
If you use a wireless router with a DSL or Cable Internet service then your laptop/computer with a wireless card can then connect to the Internet. You can also connect to a free WiFi hot spots like McDonalds, Star Bucks, the Airport etc. using the wireless card in your laptop. If you use the wireless 3G wireless broadband service, then you can access the Internet anywhere where your ISP has 3G wireless coverage. You need to check the service coverage area where you need Internet service. Once you decide what type of broadband your require, then you need to check with the various Internet Service providers to see if they can offer and the cost of the various plans. Note the download limits and the associated additional costs if you exceed the monthly download limits. Once you sign up with a Internet Service provider, their documentation will include setting up instructions and/or installation CD.
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection. Without any information about the operateing systems I can tell you the idea: First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
In this IP configuration above PC1 has the 3g modem connected. This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did. I did a little search for you on Australian Ebay to see what you can get. But I'm sure you have your own cheapbfavourite source of computer hardware as well.
