Washing Machines Logo
A
Anonymous Posted on Dec 25, 2017
Lg Tromm washing machine wiped out by massive power surge that also did in a cable box 2 surge protector devices and popped six breakers in my service panel. Is there a relay or some surge protection device or internal fuses or transformer that could be replaced or serviced to bring washer back from the grave?
Hemanth reddy
Level 2:
Habit-Forming:
  • Expert 21 Answers
  • Posted on Sep 05, 2018
Hemanth reddy
Expert
Level 2:
Habit-Forming:
Answers
21
Questions
0
Helped
15332
Points
180
Basically, we have excellent washing machine service center in Hyderabad very tough to objects are the guideline segments of choosing the washing machines. LG corporation presenting various models of Washing machines in the market and the association have a quality LG washing machine service center in Hyderabad and they deliver the benefit for satisfactory services in the time over the Hyderabad region. http://aktechnoservice.com/lg-washing-machine-service-center-in-hyderabad
LG Tromm washing machine wiped out by massive powe - lg washing machine service center...-cni0rihjrfc0cavwhfrsnoma-5-0.jpg
robert
Level 3:
  • LG Master 2,548 Answers
  • Posted on Dec 26, 2017
robert
LG Master
Level 3:
Answers
2548
Questions
0
Helped
870351
Points
8043
Sorry to s ay, I think not.
5 Related Answers
A
Anonymous
  • Posted on Jan 21, 2008
SOURCE: LG Washer
brilliant! I had the same problem with the same symptoms so i ordered the hall sensor from mcm as well put it in and $17.70 + s&h later my machine is purring like a kitten once again thanks guys D.
Anonymous
  • 72 Answers
  • Posted on Jun 19, 2009
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Anonymous
  • 632 Answers
  • Posted on Jul 19, 2009
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Anonymous
  • Posted on Sep 20, 2009
SOURCE: my lg tromm washing machine has an error code LE
Empty Washer and unplug. Hold the start button (arrow with two lines) for 10 seconds. Plug back in and put on the Rinse and Spin cycle (right hand side) I went ahead and ran that cylce (31 minutes with some bleach) and all worked well.
If problem persists call CSR. 800-243-0000
Anonymous
  • 594 Answers
  • Posted on Apr 13, 2010
SOURCE: LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
1helpful
Lg tromm washing machine
If the machine still works and that is the only problem I would use it till it doesn't, really they cost so much to fix sometimes
Wd85295npwashingmachine
I have LG TROMM washing mechine it have a fault in pcb board have you got LG TROMM WD-85295NP Washing Machine PCB
Just had power surge now lg washer will not come on
hopefully; it only wiped out the "line filter" board; and not the main board.. the line filter board is the first component the power cord connects to inside the machine.
1helpful
LG Tromm will not turn on.
I have put mine on a surge protector. It is a computer after all. It is hard to say whether or not you have suffered damage to the motherboard. Trial and error testing to see if you have power at your outlet. Hopefully you can repower and all will be well.
While watching it, it went POW and a flash of light behind it and now it's dead. Nothing else surged that was plugged in with it (cable box and amp) It's only 4 years old :-(
The power supply unit went bad...it happens, and its cheaper to get a new TV than to try to get that one repaired.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
1helpful
2answers
My LG Tromm WM2277HB washer shut down during a power surge and will not power back on. Have unplugged for several hours, still no good. Looked at solutions posted on this site and it appears my PCB board...
Well I for one would go along with your prognosis, it seems logical to me.. this IS a common occurance when this type of thing, a power surge happens.. Remember Occam's razor.
LG TROMM - awful smell while washer is running
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
2helpful
Water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
