Follow this link. This should help with your uline not making Ice.
line ice maker model ULN B12115 not making ice
SOURCE: Water dispenser and Ice maker not filling with water.
You need to replace the intake valve. First, check if it's clogged. By cleaning it, it can be fixed.
SOURCE: U-Line Echelon Model B12115
Whne you are on site, call 1-800-779-2547 for help. This is U-Line's tech support line,
http://www.u-lineservice.com
SOURCE: I have an old U-line ice maker. I can not find
The mechanical parts of those models is the same as a BI 95 or BI98. If your looking for the faceplate that would be part number 150. This includes the timer motor,gears,water switch, and hold switch. You can order this thru a parts distributor. Appliance Parts Depot or All Brand Parts should be able to help. If you want to replace the complete icemaker assemly that part number is 402
I just had the same exact thing happen to mine this week. Ice bucket filled with water and froze over. Defrosted unit & it would not make any ice at all. Called U-line & they recommended a repair company near me. He came out same day and tested it, and it was determined to be a faulty water valve. The part has been ordered & should be installed next week. I will post a follow up to this review once I see the results. Try replacing the water valve.
