Before you bother with the carb or anything else, check the fuel line and filter—it’s possible your filter is clogged or even come loose, letting the fuel line itself become clogged. This would explain why it ran for a bit after you changed the gas; you likely agitated the fuel line and let it open up a bit before clogging again. Since the line would still let a trickle of fuel through, you’d be able to start up for a couple of seconds intermittently.
Building on obsteiner response ... might first try adding some engine fuel cleaner additive to the tank ... if it runs long enough it might start to clean things out with having to manually clean the carb up...
Clean the carb. The old gas gunked up the orifices.
SOURCE: can't start toro mower. cleaned spark plug , new
Hello:
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
SOURCE: mower starts w/ priming but stops after 1-2 seconds. Air filter, gas, oil, spark plug are new
Remove your fuel filter (in the tank usually) and, replace it
SOURCE: toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
SOURCE: What is wrong with a Toro GTS5 that starts well
I had a similar problem. I'll bet I took off the carb. 5 - 6 times and cleaned it with no success. Very fustrating! One time while checking the fuel level I accidently left off the gas cap, I started it and while running I put the gas cap back on and started to mow and about 10 seconds it died. I thought could'nt be! So I loosened the cap, restarted and it kept running. Any way the small vent hole was plugged. Thats my story!. Good luck.
