Have wireless computer (older model gateway laptop) no router using alltel wireless network. loaded printer software into computer but cannot get data to printer. Dealer did not provide usb cable for initial installation. do not have secruity string , no router basically this is different from any hookup I have ever done and am lost I need help or a support phone number to talk to someone.
Hello!
Please check the manual to this device. Hope it will help you!
https://manualsbrain.com/en/manuals/1863206
SOURCE: Printer will not communicate with computers
Whenever I have seen this problem it has usually turned out to be one of the solder points on the USB connection in the printer. Of course it could be a logic board problem as well. Well done for testing your problem so thoroughly (eg trying different cables and machines) but I think it needs a repair agent now unless it is under warranty (or you can solder well). Mind you it's probably cheaper to purchase a new one then to pay to have it repaired.
SOURCE: Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
SOURCE: Going from wireless to USB install
Turn the wireless radio off on the printer so that it is not connected to the router.
1. go to menu-wifi settings and turn it off.
Kindly Go to kodak all in one home center software and click on connect your Kodak printer.
select through usb cable and click on next.
printer drivers will be installed.
go to control panel-printers and faxes and set the printer to default
you are ready to go my friend.
SOURCE: I have 1 desktop USb connected to ESP3, 1 desktop
Install McAfee Virus Software, It will Automatically fit it with McAfee Easy Web which is part of their software, it's all free through ATT Yahoo downloads.
SOURCE: Kodak ESP 7 WIFI problems
The ACTIONTEC GT124, M1000 and PK5000 Routers are not compatible with wireless-enabled all-in-one printers. These routers cannot connect to your all-in-one printer because they do not support the multicast protocol. Contact your router supplier for additional assistance and to determine if your router will be able to support the muticast protocol in the future.
