My Frigidaire - Gallery Series - stackable washer/dryer. The dryer makes a squeaking sound when you first put in the wet heavy laundry. This is rather loud until the clothes start to dry and then the sound eventually goes away until you put in fresh wet washed clothes, etc... I believe the issue is the bearing, do you think this is what is causing the dryer tub to squeak? Thanks in advance!
how do you replace the bearing? do you access to it from the back or the front?how do you replace the bearing? do you access to it from the back or the front?
You can't post conmments that contain an email address.
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
