Texas Instru... Master
- Posted on Aug 06, 2010
Re: i can't graph on ,y ti 84...
This should help you setup your calculator to do graphing.
Prepare calculator to graph
Turn StatPlotsOff
to
avoid errors:
Press
[2nd][STATPLOT][4:PlotsOff][ENTER].
Setup
Graph type
- Press [MODE] key.
- In Mode set up screen, make set the angle unit (if you
are drawing trigonometric functions)..
- Use the arrows to move cursor to 3rd line to highlight
degree or radian and press [ENTER]. The important thing is that you be
aware of the unit so that you do not get unexpected results.
- On same screen, verify that Func
is highlighted. If you are drawing PARametric plots, POLar plots or
SEQuence plots, you highlight the relevant item in the list
- If it is not, use arrow to highlight Func
and press
[ENTER] to validate.
- Do not worry if you do not have exactly the same screen
as in the screen picture (We may have different OS Versions)
Entering
the functions to draw (assuming you want to draw y= functions)
- Press [Y=] to enter function editor.
- Type in a function
- Press
[ENTER] at the end of each function.
- Before pressing [GRAPH], make
sure that all the = signs that define the functions to be graphed are
highlighted white on black. If one is not highlighted, use arrow to move
cursor on the sign and press [ENTER].
- In the screen capture 4 functions are slated to be
drawi can't graph on ,y ti 84... - 3301a18.jpgi>
Selecting
the Graph Style (You may ignore this now, because it is unimportant for
just one graph)
- Select the graph style:
The small piece of line to the left of a Y that defines a function is
the style.
- Move cursor on it and press [ENTER] .
- Each [ENTER] (on same
line) selects another style.
- On the next screen you have all the styles available on
the calculator.
- Do not select the bubble on line 6: It is for
animations. It will not leavei can't graph on ,y ti 84... - 7ed82f0.jpg the end of the plot.
Drawing
the Graphs
- Press [GRAPH] to see the graphs.
- If one of them is missing, verify that its = is still
highlighted, then
use the [WINDOW] to set the Window dimensions,
i can't graph on ,y ti 84... - 5c26e6c.jpg"h_mi">Here are the dimensions of the standard window
ZOOMING
You can also press [ZOOM] to adjust.
The
selection 6:ZStandard sets the dimensions as on the screen
Titled Window (above).
