HomeForumDishwashersKenwoodHow to fix error e4...Share on FacebookShare on TwitterShare on Google+Share on PinterestShare by Email
Question about Kenwood Dishwashers
How to fix error e4 code on kenwood dishwasher
Posted by Val Lucas on May 04, 2018
Talk to a RepairmanCommentFlag
More
Rick siegel
Contributor14 Answers
This is the flood code. Shut the power off at the main and remove all the water from the inside manually and then reset and try it.
Posted on Apr 01, 2019
Helpful0Not HelpfulCommentFlag
6ya staff
SOURCE:
6ya.com
Instant Repair Help over the Phone
6ya.com
Save Time & Money by instantly connecting to...
Helpful2.3KNot HelpfulFlag
lacocad
SOURCE:I have a kenwood KDW12SL3A.
Just got one of those at weekend and had e4 code-looked up on here and gor tis solutionwhich sems to work!
To clear the fault you need to remove the two baskets from the dishwasher.
Slide it out from under the worktop and lean it forward to about 45 degrees.
If it is already full of water, turn on the power whilst pushing the programme button, this sets up a pump out program
Posted on Jun 30, 2008
Helpful0Not HelpfulFlag
leejewsbury
SOURCE:I HAVE A KENWOOD KDW12ST3A
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
Posted on Oct 29, 2008
iano086
SOURCE:powerpoint dishwasher E4 error code
The solution below applies to a Powerpoint dishwasher but is probably a generic one for E4 problems - given that brandnames are frequently badges of convenience for made-in-china products.
The problems cause and solution goes as follows:
Problem:
Any water that leaks (for whatever reason) from the internals of the machine finds it's way down to the lowest point of the machine - down under the washzone and into the area where all the workings of the machine are located. There's a sensor there (a polystyrene float operated switch in fact) that detects this water - causing the machine to empty and go into error 4 (E4).
The solution will depend on the nature of the leak. If it's due to one of the various seals on the floor of the washer leaking or there is some problem with water level controls then that will have to be repaired first - otherwise you'll keep on getting the error. In my case however, the "leak" was actually a design feature of the machine and is easily rectified.
Open the dishwasher door fully and look at the floor of the machine where it meets the bottom of the door. You'll see a couple of plastic tubes protruding from the floor by about 12mm - one to the left and one to the right. Their function appears to be to act as an overflow if the water level in the machine gets too high (for whatever reason). This excess water is directed down these tubes and into the bottom of the machine where it can be detected - rather than letting it spill out onto your expensive floor. The weakness in this system is that it only takes a soup spoon of water to produce the error - something which might accidently happen during the course of a normal wash.
Options:
1) Leave the machine idle for a few days until the water evaporates. The sensor switch will reset and the error will be gone when you switch on.
For either of the following solutions, turn off the power to the machine by unplugging it or tripping the relevant switch at your fuse board
The stainless steel washcabinet is only slightly thicker than aluminium kitchen foil. Handle the machine gently and never force it otherwise you're in danger of distorting the cabinet.
2) Tilt the machine right the way forward so that the water leaves the area of the sensor. It'll flow back again once you level the machine but in wetting the floor area of the machine, the level at the sensor will be a little lower than before - permitting the sensor to reset. Switch on and the problem should be gone.
3) Pull the machine out from the built in unit to gain access to the right hand panel. Remove it (just a lot of philips screws holding it on) and you can just about see the polystyrene float (near the front) and the slightly depressed area underneath it - in which the water accumulates. You can poke a stick in with some tissue taped to it to mop up the water. Be careful not to disturb or damage the float.
note:
I've had this problem occur twice in as many years. If it keeps on occurring then you likely have a genuine problem with water level controls during filling or a leaking internal seal dripping water into the bottom of the machine.
Don't be tempted to block the overflow tubes - a genuine overflow could destroy your kitchen!
Posted on Feb 21, 2009
rory166
SOURCE:Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Posted on Jan 24, 2010
isadan
SOURCE:how to reset error code e4 on delonghi dishwasher
Remove all dish trays from washer, unscrew and remove lid off salt softner, tip machine on side untill all water drains from the salt softner, replace all trays and softner lid and machine should work again.
http://www.fixya.com/support/t26966796-fix_error_e4_code_kenwood_dishwasher
same problem with dishwasher powerpoint idw12 error code e4 and alarm sound comes on can you tell me what this problem is and how i can fix it.
hi i have a e4 error what can i do
e4 code wonnt come off ..all filters clean and waste clean?????
e4 . machine turns on and immediatly starts beeping with e4 on the display. please help
