Texas Instruments TI-83 Plus Calculator Logo
A
Anonymous Posted on May 17, 2010
TI-83 Plus Calculator: My TI-83 reads "INVALID DIM" when I try to graph a...
My TI-83 reads "invalid dim" when I try to graph an equation. How do I fix it?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Jul 12, 2010
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10432967
Points
622693
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
1helpful
When I try to graph it says-ERR:INVALID DIM 1:QUIT
1helpful
When attempting to solve graphing equations GETTING graphing error says INVALID DIM
If this doesn't do it, please reply to this post and give a sample equation that causes this error.
Calculator TI-83 plus. Its black. When i try to graph it says ERR:invalid DIM
25helpful
2answers
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
If this doesn't do it, could you post the exact function you're trying to graph?
3helpful
2answers
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.
If the message appears in another context, it sure would help knowing the context of the error.
18helpful
2answers
INVALID DIM error! help me!
Here is what the manual says
INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps.
23helpful
ERR:INVALID DIM
4helpful
Error invalid dim
You're trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Calculator
Well it seems that you are graphing stat points and forgot to turn them off. This can be easily fixed by going to 2nd and Stat Plot then make sure all the stat plots are turned off. This should solve your issue.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
