Casio CFX-9850G Plus Calculator Logo
Anonymous Posted on May 18, 2010
The F buttons on my Casio 9850 aren't working!
The F buttons on my casio 9850G aren't working. I can't even reset it, as you have to push F1 to reset. What can I do?
  • Anonymous Jul 28, 2010
    ok. Pull out your own casio-9850. Push the P button. What happens? Screen says: 'reset all memories?', 'push F1 to reset all'. This is the core of the problem, F1-button doesn't work! Only pressing the P-button will not reset the memory.
    Did you even read my question?
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Jul 25, 2010
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4675462
Points
21596
You can use the hardware resetting procedure. There is a button on the back of calculator that you can press using a straightened paper clip.
  • k24674 Jul 27, 2010
    If you do not understand the language of the answer or its content just ASK for clarifications. The picture identifies what calculators are concerned and the 9850 is among them. There is an arrow that point to a point marked P button. This is the one to press to RESET the memory. However if your calculator IS NOT a CASIO would you kindly supply the make and model number.
    Now, I expect you to modify the outrageous rating you gave my answer.
  • k24674 Jul 31, 2010
    Yes I read your question, even if I forgot that the procedure I suggested it required pressing the F1 key to carry it through. But I also read the RATING FAQ. And my . Thus the least that my effort deserves is a two thumbs.
    Like a calculator I need to reset my memory too. After doing so I did remember a way to reset the RAM and even to test all the components of the calculator (RAM, ROM,keys, etc.) that does not require pressing the F1/Trace key. And if a key does not respond during the keyboard testing you will know it is defective.
    If you are interested just post a comment here.
Why are function buttons (as f1 f2 f3 f4 f5 and f6) on my casio cfx-9850 not working?
Their use depends on the application you are using. You press a function key to activate the TAB that is above it (at the bottom of the screen.)
2helpful
I need a manual for a Casio calculator
http://support.casio.com/manualfile.php?rgn=1&cid=004002005
Problem with casio calculator, model 9850g plus
The Solve( command can be accessed in RUN mode by pressing the OPTN button.
In the screen that is then displayed are TABS (at the bottom).
Press [F4:CALC] then [F1:Solve]
The command echoes on the screen, ready to be completed and executed.
Bottom keys wont work ??
Your only hope is to reset the calculator by pressing the RESET button at the back of the calculator. Use a straightened paper clip. But if keys are physically busted you will have to contact Casio repair centers in your region.
How do you clear it
With a straightened paper clip press the Reset button on the back of the calculator. this will CLEAR ALL RAM. You can also, press MENU, use arrow to highlight MEM(ory) and use the options offered to you to Reset or Memory Usage. In this last option, you get a list of items (programs, statistics,etc.) Select an item in the list and press F1:Del to delete.
2helpful
Standard deviation
pulse F1(CALC), F1(1VAR) and it goes to 1-Variable Screen and shows the following:
x-(mean): 49.3333333
Sumx:296
Sumx^2:15066
xon:8.78761755
xon-1:9.62635271
n:6
I guess that you wanted the x- and xon
Also are available in RUN mode through VARS, F3(STAT), F1(X), F2(x-) and F5(xon)
The calculator wont recognise the blue funtion buttons (1-6)
Clear the ram:
1. Press [MENU]2. Press [tan] (MEM)3. Select RESET4. [F1] (yes)
2helpful
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
