When I turn on my TI-83 calculator the whole screen turns on and off repeatedly in a blinking manner. The only way for me to see the blinking cursor on my calculator is by turning the brightness/darkness setting to the maximum. However it still blinks. When I am graphing however the screen does not blink until after the graph is made. I tried to replace the batteries but that did not fix the problem. How can I fix this?
SOURCE: can not use graph function
How do I fix my Ti 83 calculator's window range error and do the graph?Because without that fixed I can't do my graph atall.
SOURCE: How do I graph parabolas?
Parabolas are forms of the base equation X^2. So press the [Y=] key, and then type in the variation of x squared that you want
SOURCE: TI-83 Plus will not let me view a table
I have just done what you said you had done, but I got a nice, correct table of values. You might have discoverd a secret command to clear memory.
Cheers.
SOURCE: Screen obstruction TI-83 Plus Graphing Calculator
The liquid crystal is damaged. I suppose the screen can be replaced. Check with Texas Instruments resellers (usually academic bookstores): they may be able to tell you where you can have the calculator serviced.
You can post an ad on the college bulletin board
TI83Plus Wanted
OK for batteries to be dead
But calculator must be alive.
Hope it helps.
