OUr Whirlpool duet washer is stuck on controls locked and we can't get them unlocked. The washer is "stuck"
We ended up holding the drain/spin button for a period of 15 or so seconds and the issue resolved.
Thank you sooo much! I was about to call a repair man for something that took 3 seconds!! This was VEY helpful!
HaHaHa.....It Worked! Mucho Gracias!!!!
Wont be looking for any repair jobs in my future!!!
PUSH END OF CYCLE SIGNAL(LAST BUTTON ON THE RIGHT)FOR THREE SECONDS AND IT SHOULD WORK.
Yes, this works. It actually says to do that under the button. When all else fails, read the directions....
thanks for the tip. problem solved.
Perfect. It Worked!!! : )
SOURCE: Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
WASHER HAS CONTROL LIGHT ON AND CAN'T GET TO RELEASE.
WHirlpool duet washer is stuck on "controls locked"
controls locked lite is on and can not clear it and opperate machine. ?
we disengage control lock and seconds later it engages and beeps constantly even when machine is in use.
our washing machine is stuck on "controls locked' right before this happened we had a load of towels that appeared to be unbalanced and came out sopping wet.
Washer is stuck on "control locked" and I can not figure out how to resolve it. I tried holding the cancel button down, and that just takes the display off until I press set and cancel at the same time.
e1 f8
holding end of cycle button as suggested worked perfectly
