Texas Instruments TI-83 Plus Calculator Logo
A
Anonymous Posted on May 07, 2010
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
I am trying to graph an equation and I get the *err:invalid dim* error message.
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on May 09, 2010
k24674
Level 3:
Answers
8093
Questions
0
Helped
4671916
Points
21595
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.
If the message appears in another context, it sure would help knowing the context of the error.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on May 07, 2010
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428823
Points
622693
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
3 Related Answers
Anonymous
  • 88 Answers
  • Posted on Oct 03, 2009
SOURCE: cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
k24674
  • 8093 Answers
  • Posted on Jan 16, 2010
SOURCE: ERR: INVALID DIM displayed on graphing calculator
The solution for the problem is simple. When you use the calculator to create statistical graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem. In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To make a long story short, you should make it a habit to reset the Ram every time you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
k24674
  • 8093 Answers
SOURCE: On my TI-83 plus calculator when i try to use the
Hi
To make a long story short, you should make it a habit to reset the Ram everytime you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
1helpful
When I try to graph it says-ERR:INVALID DIM 1:QUIT
Calculator TI-83 plus. Its black. When i try to graph it says ERR:invalid DIM
1helpful
My TI-84 Plus Silver Edition Graphing Calculator continues to read "ERR: INVALID DIM" whenever I attempt to graph equations.
25helpful
2answers
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
If this doesn't do it, could you post the exact function you're trying to graph?
7helpful
TI-83 Plus Calculator: My TI-83 reads "INVALID DIM" when I try to graph a...
Im trying to graph an equation and my Ti-83 says Err:Invalid DIM
2helpful
I am trying to graph an equation and the following appears when I hit graph: ERR:INVALID DIM 1:Quit Do you know how to fix this? The same error comes up when I try Y=X
1helpful
2answers
Cannot graph invalid dim error
18helpful
2answers
INVALID DIM error! help me!
Here is what the manual says
INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps.
I put the equation into y= and then i hit graph. when i do, the screen comes up as ERR: INVALID DIM. help i need to graph!
dont you have to chose if its quadratic or not? I'mnot 100% sure if thats right my calculator isn't working so i cant check if thats what your doing wrong ir if thats for something else
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
