Televison & Video Logo
Posted on Mar 27, 2008
Tv won't stay on
My tv comes on, the power light comes on, but it won't stay on, it goes off by itself a few seconds later. Is there a solution to this? TV turns on and immediately turns off. tried several times with the same result. does anyone have a solution? Mitsubishi model WS55809.
  • mitsub Mar 27, 2008
    Thanks for trying . There is no improvement in my TV. It still shuts off after a few seconds.
  • phishingnflo Jan 09, 2009
    i turn the TV on and receive the green light but after a few seconds the TV power turns off. this happens over and over.
Anonymous
Level 1:
Scholar:
  • Contributor 35 Answers
  • Posted on Mar 27, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
35
Questions
0
Helped
21820
Points
74
I have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Tv will not stay on
Tv won't stay on - Fixya
www.fixya.com/support/t101679-tv_stay
Tv won't stay on My tv comes on, the power light comes on, but it won't stay on, it goes off by itself a few seconds - RCA F27450 27" TV question. ... My TV will notcome on, when I hit the power button the green light flashes but the ..... Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
Why won't my TV stay on? ' Yahoo Answers
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
8helpful
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
2helpful
Protron TV, YHI power adapter goes off after a few seconds.
Sounds lika a bad power adapter. I've been repairing them for $60. Let me know if your interested. [email protected]
Tv won't stay on
Hello mrscarpenter,
This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
1helpful
Tv won't stay on
hello,
After further inspection, I believe that you have a blown convergence IC. Most posts point for two IC's. I only have one. STK393-110. There are 12 - 3.9ohm 2w resistors around it . I think they may be bad as well. The 2 Pico fuses feeding that circuit (+24/-24) may be open also.
So, with that said...... Think we have the problem cornered?
MENACE1275
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
Tv won't stay on
it is a brandnew tv, so expected that it is under warranty,, it best for you to return where you bought so the warraty will not void. Big possible of factory deffect.
2helpful
Tv won't stay on
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
