Fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Does it agitate for the wash cycle? When you get to the spin cycle, is the motor running and 3 pulleys underneath turning, and the tub is not turning?
If so, I had this issue with this model. The brake would not release, and I had to "persuade" it. Also, I had to set the plastic cam correctly on the bottom of the unit to that is would engage and release the brake at the proper points.
Did not need a bearing kit, just had adjust a few things that got knocked around by the movers. Only took me 6 frustrating hours. Hopefully take you less than 1. BEWARE the 200# force for the spring!
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
I had the same problem. You need a brake kit. it holds the drum still while in the agitate mode. the centrifical force of the water during that slow spin is causing the water to spill over the top of your drum. easy and cheap fix.
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
If your agitator is a 2 piece, it has a rachet action and turns free counter clockwise and locks to the bottom piece when turning counter clockwise.
The transmission disengages the agitator when it is in the spin mode. If you put the washer in the spin cycle the agitator should free up.
If the washer is spining ok and the agitator is not turning free you have a transmission problem.
ok i might have to put this in a 2 part solution it might not be big enough to fit here i hope this helped you in your washer it still is cheaper to repair than to replace your washer blew out its thrust bearing which is called the brake while you have the washer open grease the bearings and oil the motor you can get these same things and intstructions for this to do
