Usually, "Cable" will only work with a "Decoder" If it is unscrambled Cable, then it behaves NO different from "Normal" TV, you simply need to "Search" for your "Channels" when you first Setup, the TV for first time use, you WILL need to consult your manual to see howto do that.
Hello. The problem usually is the cable itself. In order to have a signal you must have a paid up account at the cable company and also a continuously connected line. Call the cable company to see if they are infact sending a signal to your address. If they are, then trace the signal through the house to be sure it is actually coming to your tv.
