It happens occasionally but often that in the middle of a wash program it gets stuck with the follow lights on:
Stain removel=flashing
Extra rinse=flashing
Lock=fast flashing
I need to swicht it off,wait some seconds and switch on again.
Any other solution?
Thanx
Fab
SOURCE: We have a indesit wil 143s faulty
the pressure switch should be easy to replace. it will be a round unit with wires going into it and also a small clear plastic tube attached. it is usually mounted around the top edge of the case. i would also check that the pressure system is not blocked (the other end of that clear plastic tube) as blockages may keep pressure at the switch leaving it in the "full position" pop the pressure tube off of the switch and force some air down the tube to check.tony.
SOURCE: Indesit wil 113
this is a cold fill only machine as nearly all machines today are designed that way to save energy , as you only heat the water that you need
SOURCE: all lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
