There should be a Language change option in the Menu. Our Panasonic Mini DV cam has Language options only for English, Spanish, French. If your camera does not have an English option, you may need to call Panasonic Tech Support for help.
for instructions manual i can help then u can go thru enlgish manual and see from pictorial guidance if u can change the interface lang to english instead of japanese which u can do easily if option is provided becoz menu design is same let me know if i can help more on this
Slide the [REC]/[PLAYBACK] switch to the REC position (camera icon). Set the mode dial to AUTO (green camera). Press MENU/SET to display the menu. Select LANGUAGE (head with speech bubble). Pick your language from there.
Download the driver from the site then in the help menu go to the language setup. You might have to guess your way around in this but refer to Panasonics other insturuction manuals you should know when you scroll to the english section.
Also refered to as nv-gs50e or nv-gs70e. Go to http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-75489-Camcorders#Anchor_13 it will be the third driver from the BOTTOM. This model has been discontinued so support for later windows editions are not likely. Windows 2000 is the last version you can always run your compatabilty mode with 2000 for optimum preformance. PAL Mini-DV Cameras/recorder
1.find a japanese person and ask him to do it for you 2.find an english manual and follow the same steps 3.find an online translator and try to translate the steps
(those are working if your camera support english language)
