Kenneth Cole 1213 Wrist Watch Logo
Posted on Mar 30, 2010
How do u operate unlisted ul 1095 no instructions came with watch
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 08, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1479
Points
Download the manual here
http://www.genevawatchgroup.com/pdf/unlisted/UNLISTED-GENERAL-ANALOG-DIGITAL-INST.pdf
Ul1002. How can I turn off the beeper?
Watch instructions here I think. A full make and model are useful rather than guessing
https://static1.squarespace.com/static/58ca120515d5db2d0e0f609e/t/58da90d4be6594b226a75890/1490718936270/UNLISTED-GENERAL-ANALOG-DIGITAL-INST.pdf
Or any of these?
UL 1002 - UL Standard for Safety Electrically Operated Valves ...
standards.globalspec.com > std
Nov 30, 2006 - Find the most up-to-date version of UL 1002 at Engineering360.
Other Standards > Underwriters Laboratory Inc. > UL 1002
www.roadauthority.com > Standards
UL 1468 Direct Acting Pressure Reducing and Pressure Restricting Valves. UL 1469 Backflow special check valves of 3/4-inch (19.1-mm) through 10-inch ...
UL 1002 : UL Standard for Safety Electrically Operated Valves ...
global.ihs.com > doc_detail
UL 1002, 7th Edition, November 30, 2006 - UL Standard for Safety Electrically Operated Valves for Use in Hazardous (Classified) Locations These requirements ...
Kurt S. Adler Replacement Bulb for UL1002, 3 Piece Set, Multi ...
www.amazon.ca > Replacement-Bulbs-Ul1002-Bubble-...
Kurt S. Adler Replacement Bulb for UL1002, 3 Piece Set, Multi, C7: Amazon.ca: Home & Kitchen.
Dec 16, 2020 • Watches
How to make the hands work on a ul 1095 s60 watch?
Try fitting a new battery and make sure the winder used to adjust the hands is pushed all the way in. Some watches have a 'stop' feature when you pull the adjuster out.
Dec 02, 2018 • The Watches
Unlisted Kenneth cole ul 1069 all other functions work except hands they stopped when trying to set date. what do I do to get hands working again?
your watch has two battery.
one battery for Digital
other one for Analogue
perhaps battery for analogue died
you need to change one battery
Why does the hands on the ul 1173 watch does not work?
UL1173 watch has two battery, one for digital other one for analogue.
analogue ( Hands parts) battery died, you need to change battery.
Manual kenneth cole for watch ul 1181 where can i get the manual
i am not understanding ......
you need Manuel for replacing battery ?
or
you need Manuel for setting up digital part of your watch ?
Kenneth cole unlisted watch manual ul 1102
For the UL 1102 S60, how do you open it to change the batteries?
Jan 09, 2012 • Watches
17helpful
Looking for instructions on a (UNLISTED watch MDL#1070)
You can get the instruction manual here:
Jan 05, 2010 • Watches
7helpful
The watch did not come with instructions and I
Top Kenneth Cole Watches Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
