My maytag front load washer keeps making the draining noise. We pulled it out away from the wall and checked the hoses. There was a lint clog at the end of the hose so we got that out. The door won't unlock even though there appears to not be any water left inside, only wet clothes.
Try unplugging the washer for 30 seconds then run a rinse and spin cycle. If it is still acting up you can remove the top panel and reach your arm down the front right side and find the door latch assembly. At the bottom up it is a pull tab. Pull that down and you will release the door latch. Image Whirlpool WP8182634 Door Lock Latch PartSelect
SOURCE: Maytag Washer top load
very difficult, the is a filter within the drum area but not easily accessable. you could try removing thesump hose and try to clean through the hole, otherwise major job. Regards Advisor
SOURCE: clothes still wet washing on Maytag neptune
Your pump, or the hose between the pump and drum, might be clogged. Could be spare change from unemptied pockets.
SOURCE: Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
SOURCE: Clothes still wet after final spin cycle
It sounds like you might have a broken belt or the belt just slipped off the pulley!
SOURCE: Maytag Washer leaking from the bottom
It will be the normal trial and error. Remove the top lld and the back panel.statt the wash again and start looking for anything obvious. Start from the soap box, then carefully look down the sides and then if nothing seen, switch machine off and tilt machine untill you can see the underneath. Look for any areas where there is water .(when visible start looking a little higher untill you find the spot.) Most of the underneath areas are likely rust spots that have broken through.. On occation the pipes are perferrated and have a small leak. All observation.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
