SOURCE: VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
SOURCE: 42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
SOURCE: RCA LCD TV L42wd22YX5 - Gets unusual signal to all inputs
Tries Ebay.com,Shopjimmy.com for used signal tuner main board.
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Testimonial: "alteans is very helpful."
