Texas Instruments TI-84 Plus Calculator Logo
Posted on Mar 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i type in a question on my TI-84 calculator the answer usually always ends with "e" HELP
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Mar 24, 2010
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443202
Points
622693
You're in Scientific or Engineering notation.
Press the MODE button to enter the mode editor. Highlight "NORMAL" on the first line and press ENTER. Highlight "FLOAT" on the second line and press ENTER. Press 2ND QUIT to exit the mode editor.
Complex number
Try entering on the same command line your calculation followed by the ToFrac command. That should work. Here is a screen capture from a TI83Plus in complex mode (a+ib).
My TI 84 won't convert my imaginary numbers to fractions. I typed in 1/(1+i) and it won't convert the answer to fraction form. It keeps saying Error Data Type
The TI-84 works with real fractions. It will not convert complex numbers to fractions.
You can convert the real and imaginary components to fractions separately. For your example, 1/(1+i) is .5-.5i. Converting .5 and -.5 to fractions, you get 1/2 + (1/2)i.
Ti-84plus keypad for ti-nspire w/touchpad while in a+bi mode i enter the the problem (2-5i) / (1-6i). once i press "ENTER" i get a decimal. i want the answer in frac form, but when i press...
Here is screen capture of the calculation, performed on TINspire with TI 84 plus keyboard.To type in the imaginary unit use key sequence [2nd][dot], do not use [ALPHA][X^2] for the letter I.
k24674_90.jpg,
2answers
What is 126 divided by 9
With the TI-84 type in the following: [1] [2] [6] [divide] [9] [=]
This will give you 14.
1helpful
5/4x-18=-3 Ti 84 plus One: just press enter/solve Two: press 2nd Test (Math) then press enter Every time I put in and equation using the above method for the equal sign. it either takes me back to...
If you wan to solve an equation using the SOLVE feature you enter it as follows (your example)
You should rewrite it as 5/4*X-18+3 (= 0). Implicitly, the calculator assumes that the right side is ZERO and you do not enter any right side nor an equal sign.
Type in
5/4 [*] [X,T,theta, n] -18 +3 [ALPHA] [ENTER] (SOLVE)
You should get an answer -780/47 or the decimal equivalent (depending on display mode.)
4helpful
Any sin, cos, or tan function problem always gives the incorrect answer. I can use my TI 55 that is 30 years old and get the correct answer, but my son's TI84 plus silver edition is incapable of giving the...
Make sure you have the proper angular mode set. The TI-84 can work with degrees or radians.
Press MODE to bring up the mode screen. Use the arrow keys to highlight either "Radian" or "Degree" on the third line and press ENTER. Press 2ND [QUIT] to exit the mode screen.
If this doesn't do it, please reply to this post giving an example of a calculation and the answer you're getting from the calculator.
6helpful
2answers
Wrong trig ratio
Your calculator is set in radians. Press mode key. Arrow down to 3rd line. Highlight degree and press enter. Your calculator is now in degrees, not radians. To get out of the mode screen and back to home screen, press 2nd and then mode.
2answers
Ti-84 turns off
Usually this means that you need new batteries.
When I type in (0.02) to the power of 2, it displays E. I want decimals
If number format in MODE is set to Normal, and if the (absolute value of) the number is smaller than 0.001,the calculator displays it in scientific notation( with the E). By the way E( ) stands for x10^( ).
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
