HI,
Probably the t con broad is faulty. t con board id the on which drives the LDC panel. I some tvs its not possible to replace the T con board as it would be integrated to the LCD panel normally in 32 inches and bellow. In others i would be separate board which is replaceable individually. I have added a video to know how to locate a t con board which is replaceable individuality. As you didn't mentioned the model number its not possible to add the exact image. In all most all the tvs T con Board (individuality replaceable one ) will be placed on the top center of the tv cover with a metal shield. If its incinerated to the LCD panel then inside the LCD protection metal chassis. Check and fin which one you have.
MB, your set has one or more defective LCD panel tabs. The only true fix is to replace the screen which will be big $$$. There are youtube videos that will show you how to patch the problem. Just search LCD panel tabs and several videos should come up.
hi, first of all replace all the three crt base socket of ur tv's three crt guns. also check the line output transformer (LOT). my be its insulation have some problem that's why you hear a noise. noise of the high voltage leakage . if so u have to replace the LOT. ok
The convergence ICs are starting to go and need replaced ASAP. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
There is a problem with the self focus function on the TV set. We have had ours replaced twice. Once under warranty and once out of pocket. After you get it fixed, if you do, the self focus option needs to be set to "OFF" and only focus the TV when necessary. Ours is going out again unfortunately. You would think paying what we all did for this paticular TV we would or received a higher quality project. However, Samsung only hymns and haws about it and offern absolutely no help other than TV repair people in our area that they know about. (which seem to charge absolute top price).
We tried to get the screen replaced while under warranty and were unable to Samsung wouldnt cover it. Now we cant even locate the top layer screen and pay for it ourselves.
I dont think I will ever purchase a Samsung TV again. Never again.
