The Acme Supreme Juicerator that we bought in the 70's needs some new parts and pieces. Where can we obtain a centrifugal switch and a new cutter? SUPREMEJUICERator by Acme Mfg. Co. Model 11JE needs a blade
You can also try http://www.fernsnutrition.com/acme_juicer.html for the 6001 Acme Supreme Juicerator, the blade was $30 and the clutch/nut was $10. I suggest you buy the clutch because they wear out and if you only get the blade it will run "off balance." I just bought these parts for my 70's juicer about a month or two ago.
I need a part for the citric device. There is a piece that allows the machine motor to turn that cracked. Its the size of a nickel.
The cutting blade can be found at http://www.waringproducts.com/ret/. Waring now makes the juicers. Good luck!
SOURCE: Where can we locate a parts store?
TRY WARING AT 800 492 7464. MY 11JE IS
STILL GOING STRONG.
I need juicer s top part to squeeze juice
i need for the juice extractor mj-66pra a food pusher and a cleaning brush can you help in telling me wher i might be able to get these thanks fran
I have a ACME Juicer model 11JE21, Cat: 6001..I need the part that holds the blade.. bolt/nut.. where can I find it?..
