I have a Maytag top loader model A412. I turned the water on one day and it began to blow smoke. Later I tried it again, and it began filling with no problem. The belts were burned, so replaced them. The tub fills and empties, but the agitator does not move when the wash cycle starts. If this is a transmission problem, is it worth trying to repair or replace myself, or should I just cut my losses and replace it. It is probably 15 years old.
SOURCE: Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write. You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you. What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving. During the wash cycle, the top half is just sitting still. If this is wrong, please let me know. If this is right, you have a sort of simple fix. Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off. When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there. You can put your finger on the lips and lift it straight off. Then you will see a cap with a bolt in the center. Remove this bolt (7/16" with long extension). the agitator dogs (Sears part #387091) . You should see these under that last cap tha had the bolt in it. Remove the auger (just slide it up and off), remove the dog holding cap. Remove the dogs, but be sure you remember the way they go back in. Next is the tricky part. Take the cap upside-down, and place it back in the auger. Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole. Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator. Make sure the locks and stuff fit right between the two. Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap). If all goes well and right, you should be able to roll the auger one way and not the other. If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along. Good Luck!!!!! Jim
SOURCE: washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
SOURCE: maytag se1000 washer
sounds like the brake is not engaging properly(locks the tub for agitiation) wouldn't say transmission just yet, don't know the age but probably a few hundred dollar repair, i would recommend a maytag guy to do the repair, requires special brake tools and such,
