SOURCE: have fujifilm finepix f40fd. protected card shows. wont clear
I had the same problem with a Fufifilm camera. When I looked closely at the memory card I noticed a little white sliding button on the left hand side. When it is in the down position the card is locked or protected. Just slide the button up and put it back in your camera and it should work.
SOURCE: When I play back my
try a memory card reader and see if the photos are detected. if everything goes well the problem is with the card read session. so foramt it once with a back up of photos in ur pc
SOURCE: fujifilm finepix f40fd
An update to the initial posting. As a warranty service provider, I can state that physical damage as a result of mis-use is NOT covered under warranty. Lens problems caused by dropping the camera are considered mis-use and are not covered. There is a good posibility that the lens assembly is just out of timing and can be rebuilt, but the cost to do this will not be paid by the manufacturer.
I don't want you to believe that this repair will be for free as it will not.
Regards,
Dan
