SOURCE: 900 rmk going down trail and died No spark now
CDI box went out, or your stator poped. only things posssible, coils dont go out at the same time
Check
engine light comes on and off, these are indication that there is some
error code stored in your vehicles ECM. The engine module computer
needs to be scanned. These will give the code and as per the error code the
further problem can be detected and confirmed. The engine light
indicator blinks or remains steady on dash when engine computer
noticed any problem with any engine electrically operated components.
For
more help, I suggest you to refer the help links provided below. These will let
you know more about which areas to look, check, when there is engine light
coming up on dash panel.
Click
the link below: -------
http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
http://howtobyme.blogspot.in/2012/02/check-power-train-message-with-orange.html
http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
These
details will help.
Thanks.
