Washing Machines Logo
Posted on Mar 10, 2010
Washer wont spin on normal or heavy loads but it will spin on knit loads? It spins counter clockwise on knit loads but doesnt spin clockwise on normal or heavy loads.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
86
Points
Sounds like the motor. Motors work in two directions and one direction can die while the other one works.
  • Chris Eltringham
    Chris Eltringham Jun 29, 2014
    drain pump assembly was clogged - but all suggestions on page had me look at all options to troubleshoot. Thanks you saved me money 115.00 plus taxes and whatnot. Thanks!
Frigidaire Front Load washer (25 yrs old) fills completely but does not spin for the wash cycle. Manual timer clicks and buzzes but drum does not spin nor does the timer advance.
Sure sounds like your timer has bit the dust. I'm not sure if the timer is still available. You have a great washer there. Good luck.
2answers
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
It wont spin
Your washer has a lid switch.97a908d.jpg If the switch is broken the washer will not spin. The pump is mounted on the motor.c5ccc2f.jpg
In the wash cycle the pumps turns counterclockwise. In the spin cycle the pump turns clockwise, forcing the water out of the machine. So if that lidswitch is dead then she won't pump OR spin. This video shows how to get into your machine and the next one shows how to replace the lid switch
Use this GUIDE to help you
Did I help?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3helpful
Washer spins but water does not discharge. spin
Tip machine back and remove the bottom panel, 3 screws. You will then see a large tube at the front, unscrew in a counter clockwise direction, and remove. Clean pin trap lubricate o ring and replace back into recepticle
Locked up agitator,
If your agitator is a 2 piece, it has a rachet action and turns free counter clockwise and locks to the bottom piece when turning counter clockwise.
The transmission disengages the agitator when it is in the spin mode. If you put the washer in the spin cycle the agitator should free up.
If the washer is spining ok and the agitator is not turning free you have a transmission problem.
PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
2answers
Aqualux 1200i
did you happen to solve the problem? I am having the same exact issue with mine...washes fine, but won't do the spin cycle. it spins counter clockwise really slow at first, presumably to balance the clothes, and then starts to spin up clockwise (to do the spin cycle) but then whinnies and then stops....!
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
