You may want to try a signal booster,or a different arial.Not sure if your old CRT or arial was digital ,but you should have a tools button on your remote or a diagnotic option in your menu that will show signal strenght.I have a Terk HDTVo.It is a small bomarang shaped antenna that pics up stations 50 miles north (direction it is pointing)and the only issue is when storms roll thru.I have added a motorola 484095-001-00 signal booster and that has solved most of the issues with the farthest stations plus added a few more from different directions.You could also add a antenna and if your original arial is run with coax just use a diplexer to combine the signals.Well hope this helps and good luck.
