Cars & Trucks Logo
Anonymous Posted on Mar 07, 2010
Suzuki swift 2007.changed battery in remote,and now will not work,yes battery is in right way. changed both remotes,both stoped working.
Anonymous
Level 2:
Sergeant:
  • Expert 180 Answers
  • Posted on Mar 07, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
180
Questions
0
Helped
59767
Points
569
They need to be reprogrammed. You can take the car and the remotes with you to a dealership and have them reprogrammed. Make sure to take both remotes with you.
Testimonial: "chears thought i could do this my self but after three headaches, will take to dealer"
Suzuki swift remote key battery is dead,how do i start the car with the key ?
this is USA forum is car in USA/.
we cant guess where. and matters.
i guess you didnt lose the key and fob.?
and never tried sitting in car and starting it the NORMAL
way. that be first.
to remote start any factory car fitting out with this bs.
one must have what>?
1: starts the normal way. logical no?
2: for remote to work a good remote battery. (make the transmitter work and buttons on fob)
3: the car must not be in ALARM for any reasons.
there is a huge list of reasons, like, door ajar. and a large list.
if you scan the PCM in the car it tells you all this. OBD2 scans.
that is to protect you from injuring others.
It must be safe to remote start or it will not.
Our keyless remote stoped working on our 2007 chevy impala. we put a new battery in and proceded to reprogram it according to directions, it still will not work. is it that we just need a new remote or...
If your vehicle accepted the programming codes, then it tells me that your vehicle sensing is working and that your remote worked at least during that period.
Whenever, you change batteries in a remote you should clean the battery and remote contacts with a pencil eraser to get rid of an corrosion.
1helpful
I have a Suzuki Swift '06. The keyless entry remote has stopped working and I suspect the battery needs changing. I tried opening the key case but stopped after finding the mechanism unfamiliar. Can...
some remotes are not repairable,when the battery dies you have to replace the whole unit,yours may be one of this type, you may have to go to a SUZUKI dealer & get another one & have it coded.......hope this helps......cheers.
2helpful
Remote key does not open /close door lock
Hi.
It seems that the remote key need a battery change. replace the batteri inside the remote key.
If this is not curing the problem you might be in the situation where the transmitter (remote key) or the receiver (car) is defect.
In this case you need help from Suzuki.
Good luck
1helpful
3answers
My key fob on my suzuki xl works part of the time then stops. how can i check it. thanks
Change the Battery!~! Thats how they act when the battery starts going south!
We have changed battery in our key push buttom remote and now it does not unlock or lock or set the alarm on the Suzuki Swift car, prior to changing battery it worked perfectly can you advise how we...
check battery in fob may be bad or weak and notify a dealer for ur code setting should not have lost it battery may be new doesnt mean its not defective
1helpful
Remote key fob does not unlock or lock car
It may just be a battery problem. Replace the battery of your remote fob. If it will not work, try to reposition the controller beneath the dashboard.
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Expert? Answer questions, earn points and help others
