I have lost the directions on how to change for the daylight savings time and only need to move it forward one hour, but am completely lost. Please offer the simple solution that escapes me at this time.
Thank you.I have lost the directions on how to change for the daylight savings time and only need to move it forward one hour, but am completely lost. Please offer the simple solution that escapes me at this time.
Thank you.
AnonymousApr 03, 2008
change timechange time
You can't post conmments that contain an email address.
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date 2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
Set Analog Watch
Pull out the watch crown on the right side of your Arnette analog watch.
Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic: Time and Date Setting
Pull crown out to position 2 and rotate clockwise to set time.
Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
Push crown back to position 1.
Analog Digital: Time and Calendar Setting
Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
Press pusher B to adjust digit.
Press and hold pusher B to adjust digit automatically.
If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions. Hope this helps.
The analog setting of the watch takes place by pulling out the knob (kind of tough) and adjusting, like a regular analog watch. The analog and digital displays are will NOT stay in sync, unfortunately.
In the time mode, press the upper right button for 2 seconds and the time display will flash. Then press the same button untill the entire time will flash, or both hour and minutes flash at same time. When the hour and minutes flash at same time, this adjust mode is the adjusting of the analog left display (A1). Now, press the lower button for adjusting de hour shown at the digital display that shows the same hour at analog display. This method is to adjusting the 8982 that is the "father" of 8988. Like a Citizen collector, and don´t know any website that you can view the setting instruction of 8988, only the 8982 is disposable here: http://www.citizenwatch.com/downloads/techguides/8982.pdf
Dear I received gift of G-300 Casio watch but could not adjust the analog time where as digital time adjusted. Could you please help me to guide for adjsuting its Analog time.
Thank you.
change time
