P-Touch Analog time is 1 hour off digital time. Compass function minute hand is 10 min on clock face out of line. Other funcitons, hands do not line up.
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
The analog hands and face are clean looking and manage to give the watch a classic face. It won't turn any heads, positively or negatively. The hands are rather thin and silver which makes it blend in too easily with the face. Stupidly, Casio put a vertical and horizontal silver line on the face which further causes the hands to be visually lost. The hands aren't hard to see, but because they blend they aren't easy to see either. And there is no second hand at all; but the digital portion covers that function.
The digital portion in the bottom can only display two rows of information. So it's either day/date, or time/seconds. The top row is hard to see because the face shadows over it partially. The numbers are on the small side; not for old eyes. The digital portion has all the fundamental functions: time/date, hourly chime, chrono, 3 alarms, count down, dual time, and even "data bank" which is a very crude phone/number data bank.
The LED's are the old 80's yellowish tinge type and do a very poor job of illuminating the face... but if you're in the dark, it'll do the job. The hands have glow in the dark paint on them which also helps you just barely make out the time in the dark.
There is just nothing great at all about this watch; but it does everything you REALLY need a watch to do. Couple this with the 10-year battery, 100M water resistance, and $25 price tag, and you have something that just gets the job done reliably and economically. It might be plain vanilla, but it's real and hits the spot.
The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
After the time is set, press the upper left button to exit the digital time setting function.
Setting Analog Time
You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal 2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m). 3. Push and hold (at least five seconds) the center crown 4. Watch will beep and word (SYNCHRO) will appear in the display. 5. Use the top + button to line up the minute hand right on the 12. 6. Use the bottom – button to line up the hour hand right on the 12. 7. When finished, press crown and you will go back to time.
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used: 1. Activate Crystal 2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m). 3. Push and hold (at least five seconds) the center crown 4. Watch will beep and word (SYNCHRO) will appear in the display. 5. Use the top + button to line up the minute hand right on the 12. 6. Use the bottom – button to line up the hour hand right on the 12. 7. When finished, press crown and you will go back to time.
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
1. Activate the Crystal. 2. Select the "units Mode". 3. Press and hold the "T" until it switched to "syncro" mode. 4. Now using the + and - move the hands to the 12 o'clock position. 5. Press "T" again to set.
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode. 2. Press the centre area on the face twice to display 24hr/12hr 3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200. 5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
This problem may be due to your analog hands being improperly zeroed. To find out, try this:
1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr"
2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem.
If this is the problem, you can can correct it by zeroing the hands as follows:
2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does.
3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock.
4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock.
5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out.
If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
