My konica minolta copier says call sevice code f-35-3
Sir,
Fuser Code (Hot Unit has over heated) To reset you will need to go to 25 Mode to enter his mode you must turn off the machine then holding down the 2 and 5 button turn on the machine, hold them 25 down for at least 30 second once in 25 mode select SW (soft Switch) select "3" then "2" it should be a "1" change to a "0" then exit and turn off the machine and turn "ON".
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
model?
