Winter Sports Logo
Posted on Oct 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an 2001 Polaris XC 500 that sputters and backfires
I have an 2001 XC 500 that sputters and backfires at low rpm. At high rpm it runs great. We have cleaned carbs, checked reed valves and found nothing. We are thinking stator or electric problem with throttle kill switch or changing coil wires or CDI and I even read possibly a problem with the clutch? What would be our best bet to try next?
vtrktrmn
Level 2:
Sergeant:
  • Expert 201 Answers
  • Posted on Mar 04, 2018
vtrktrmn
Expert
Level 2:
Sergeant:
Answers
201
Questions
0
Helped
107296
Points
569
Before you do any of that check exhaust for restriction.
5 Related Answers
Anonymous
  • Posted on Sep 04, 2009
SOURCE: polaris rmk 500 backfires when it gets hot then
Ok this sounds like a similar problem that I have had with a 500xc engine...This engine has been running fine for the last 5 yrs until a few weeks ago when it became a pig to start and when it did only run on one cylinder eventually running on both and when it gets to a certain temp would cut out and then not start again for 5mins, changed everything we could think of, checked compression, barrels fine, carbs clean new cdi, coil, plugs, leads, fuel pump and pipes, then someone came accross with checking the resistance on the temp sensor on the top of the head which were different values to the the book and on another identical engine, I borrowed a spare sensor and although still a pig to start it was an improvement when running, need to buy a new sensor to rule it out
, can anyone else shine some light on this?
hotrodtod38
Todd Bradshaw
  • 141 Answers
  • Posted on Feb 15, 2009
SOURCE: polaris 500 xc backfiring through carbs, running on 1 cylinder
timing or cam
Anonymous
  • 12 Answers
  • Posted on Jan 24, 2010
SOURCE: i have a polaris 1999 500 xc and i just had the
check choke cable to make sure you have some free play in cable when choke is off.
Anonymous
  • Posted on Feb 27, 2011
SOURCE: I have a 1999 polaris
look at your drive clutch if the rollers are bad it will engage to early and bog down the engine
Anonymous
  • 58 Answers
  • Posted on Oct 05, 2012
SOURCE: 2012 Polaris Ranger 500 smoking, less when warm
sounds like comutator needs replacing
Lots of gas consumption on 2001 polaris xc 600
if your air filter is clean then I'd check the float and float height in the carb
Jan 02, 2014 • ATVs
4 wheeler backfire on start
incorrect air fuel mixture or a leak check for damage to the intake boot or airbox
i need to know more about how its running at low mid and high rpm to help you troubleshoot and you need to check for leaks especiely the intake boot if the intake boot is leaking that will need to be fixed before running the bike asumeing that is ok or fixed run the bike listen to it at idle standing is it surgeing with a good fast acceleration off the line with you siting on the quad ? or just realy rough ticking over with little guts off the line ?
midrange rideing how does it feel is there a bwarrr noise as u accelorate hard or does the engine roar up fast
is it reaching a good top end with good pulling power or poor pulling power
are the backfires constant or mainly whyle slowing down from high revs
if all are effected but there are no leaks then it may be float / fuel level that needs ajustment fuel level in ur float bowel effects all stages of rpm low mid and high
A rich problem gets worse as the engine heats up.
A lean problem gets better as the engine heats up.
hope this helps if u dont fix it your self first try and do them little rpm backfire tests for me itl tell me a lot
3helpful
Polaris xc 500 twin one cylinder not running right
DOES THE CYLINDER HAVE LOW COMPRESSION. IT SHOULD BE SOMEWHERE AROUNT 100-130 PSI AND NO MORE THAN 15% DIFFERENCE BETWEEN THE TWO CYLINDERS. IF IT IS LOW, A REBUILD IS GOING TO BE REQUIRED. IF IT IS OK THAN CHANGE THE PLUGS AND DO A CARB CLEANING AND SYNC THEM.
HOPE THIS HELPS
1helpful
3answers
I have a 2001 polaris sportsman 500 H O and it idles great but when you give it gas it sputters and backfires like your in reverse, i had the carb rebuilt still doing it, please help!!
well i am curently haveing the same problem i have never had a problem with it before but something went wrong wen riding it last night ... if you have figured out what it was or need updates on how mine is going email me [email protected]
Apr 15, 2010 • Polaris ATV
I'm trying to solve a sperformance problem with my
Replace the sparkplug boot on end of wire its starting to breakdown and carbon track internally!
Apr 14, 2010 • Polaris ATV
2answers
Backfires at half to full throttle, idle is ok, low rpm
change Your spark plugs. If that doesn't help the carburetor needs to be cleaned and checked. Hope that helps.
May 24, 2009 • Polaris ATV
2answers
Xc 600 stalling
when it stalls, is it on a warmer day? ie 20+ degrees? is it overeheating or hot? If you have never had the carbs serviced, the summer/fall may be a good time. inside the carbs, you have differnt circuits, they may be gummed up. Good luck
Top Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Winter Sport Expert? Answer questions, earn points and help others
