This is a new problem -- I've been using this computer and this printer together with this software for more than a year.
When printing from Mail, Firefox and Quickbooks Pro from my Mac Powerbook running OS 10.4.11, the default is coming out as landscape instead of portrait. While I can go into page setup and fix it in Mail and Firefox, QB Pro 2007 Mac doesn't have an option for page setup when printing invoices created in the onboard form designer. My invoice form is set as portrait, but when I print to PDF or to my printer, it comes out landscape, cutting off the bottom of the invoice. It doesn't even print a second page with the rest of the invoice, just cuts it off.
Is there a way to change the default setting so that unless I change it, my printing is automatically set to portrait?
I've had a few other weird printing issues (can't print from InDesign CS2), so I just downloaded the print driver and reinstalled. That didn't fix it. I also deleted the printer and added it back in. Still can't print my invoices.
SOURCE: When I try print invoices
Which quickbooks are you using? Which platform (Vista, XP etc) If you have Vista, only QuickBooks 2008 and 2009 will work.
SOURCE: Hp6500 won't print my invoices from Quickbooks, Help!
Quickbooks generally give problems with every darn printer on the planet.If you are not using the latest quickbook version then try this. save the document on your desktop and then close the original file.Then open the saved file and select the path to print and click on file point to set print area and then click on set to print area click on ok on the dialog box.Then try to print once again and see if it works.....it should if it doesn't call in to HP at 18004746836 and we will be happy to resolve your issue via a remote access session with your computer
groupwise is doing the same but a new user is ok and prints normally
HELP!!!!!!!!
I have the same problem using a mac and an HP 7100 series printer only I mine don't give the option to change the orientation.
