I need a TM55 treadmill cable PN 012-0827-00. Would you have it in stock .if not how long would it take to order and what is the cost? Stephanie Omardeen , Healthy Heart Ltd.
To connect your TV to your Technogym 700 treadmill, you will need to use a HDMI cable.
First, locate the HDMI port on your TV. It will typically be located on the back or side of the TV.
Next, locate the HDMI port on your treadmill. This will typically be located on the console or control panel of the treadmill.
Once you have located both the HDMI port on your TV and the HDMI port on your treadmill, simply connect one end of the HDMI cable to the HDMI port on your treadmill and the other end of the cable to the HDMI port on your TV.
Turn on both your TV and treadmill, and you should now be able to see the display from your treadmill on your TV.
If you do not have an HDMI port on your treadmill or TV, or if you are unable to locate the HDMI port, you may need to use a different type of cable or an adapter. Please consult the manual for your treadmill or TV for more information on how to connect the two devices.
you must have short circuit maybe some diode, etc. for that reason the capacitor or condenser burst. see the block diagram and test with DVOM, God bless you
Yes the repairmen is o.k when he says the controllers nothing to do with the calorie counter. See the block diagram attached, the problem is the display board or upper board. However adjust the REED switch, test for open or faulty, clean it, and tigh very well the connector b) tight the ribbon cable for keypads inside the display board. c) replace batteries from display by new one, with the same polarity, same markay such hybrid rayovac. c) clean the contacts battery. God bless you
I use Sportsmith for most replacement parts. If they don't have what you are looking for, most often you will need to contact the manufacturer of the equipment for OEM parts.
I found 2 different part numbers for this housing, but I suspect that they are actually stock numbers for the different stores. Partselect.com calls it their PN PS328166. Appliancepartpros.com calls it their PN AP3085317. Take your pick from whom you want to buy it, or look for another vendor. I did an internet search for appliance parts to find these two vendors.
