Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
You may just have over sudded the unit by using the wrong detergent or too much. After you have the unit running again test the unit with no detergent and see if you activate the waterproof system again. if you do then you will probably have a split hose inside the unit.
Miele 4840 Touchtronic, had same problem... Waterproof System acitvated. Followed directions above and the error code cleared. We are running empty to test. Just fyi
