Remove roller from printer and
Just rotate the rubber from plastic
Hope this will work for u. . . .
Pickup rollers suffer from several possible faults-
- Cheap paper can lose fibers that clog the roller reducing friction
- Rollers can harden, reducing their 'stickiness'
- The slightly roughened surface of the roller loses its roughness
Sometimes the roller will improve with cleaning but don't use alcohol since this will leach softeners from the roller so a mild detergent is better such as window cleaner and a fiber-free cloth; you don't want to worsen the problem.
Some mfr.s (HP for one) have produced short-lived rollers that required 'roughening' pads and a small program to drive the roller for seconds to minutes to restore the minute 'fingers' to the roller.
If a high-usage printer, you may have to replace the pickup roller and the labor involved varies greatly.
One 'quick and dirty' method that sometimes works is to reset the paper length to 'legal' (runs longer) and put a good quality paper sheet that has been wetted with window cleaner in the feed slot and allow the roller to rotate on that surface by holding the end of the sheet.
The printer will eventually error out with a 'misfeed' that may require resetting.
Allow it to dry again before trying to print.
http://www.laserprinterservices.com/parts.html
https://www.partsnow.com/Forms/Login.aspx
http://www.thelaserguys.com/Printer-Error-Codes_ep_42.html
Hope this helps helps. Please keep us updated and remember to rate this answer.
