Samsung DLP HL-P5663W 56" TV Logo
Posted on Feb 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung DLP TV shuts off
I have a Samsung DLP TV, model HL-S5086W that intermittently shuts off after about half an hour. Once it is warmed up, it can shut off once an hour or ten times an hour. I have a Samsung DLP6163W and it keeps turning itself off. Ten or twenty times then it will stay on for an hour or two. It is intermittant and is driving me nuts. Any help would be appreciated.
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Feb 25, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783167
Points
6681
First thing I would suggest is to check and make sure that the cooling fan is working properly. The lamp may also have an intermittent failure as well.
Do a visual inspection of your lamp. In your case check for a fogged condition. If the failure is intermittent, the lamp will look fine to the visual check.
The newer TVs have blink codes that can be use to determine if the lamp is defective. Check for the LEDs on the front panel blinking and count how many and the time intervals they blink.
If you need any further assistance, let me know.
Anonymous
Level 3:
Genius:
  • Master 3,587 Answers
Anonymous
Master
Level 3:
Genius:
Answers
3587
Questions
29
Helped
1147275
Points
9064
Sounds like your power supply is going south...check the voltage coming out of the wall first
  • Anonymous Feb 25, 2008
    So, you have Two of these with same issue? I'd suspect the power source, since that's what they both have in common.
    do you have a voltmeter around, to check the voltage into the device? Florida is known to have issues with power brownouts. You might consider running them from a UPS or battery backup system.
1helpful
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Samsung HL-S5086W 50-Inch DLP HDTV keeps turning off for no reason
After turning off do the LEDs on the front panel blink on and off?
If so, you may have an issue with the lamp. Probably needs replaced or repaired.
5helpful
3answers
Samsung dlp model hl- S5086W making continious humming noise, has nothing to do with volume. Can I replace fan or wheel myself?
Most likely color wheel since most are defective right out of the factory--- someone has a step by step procedure to replace with pictures-- try google- samsung colorwheel -- fun job easy to do!!!
SAMSUNG DLP HL-S5086W
check the horizontal transistor if, good.re solder your tv.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
