Washing Machines Logo
Posted on Feb 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my zanussi jetsystem 1400 8kg the water is not going into the machine do i need to reset it and how do i do it thanks#
Gerry Harvey
Level 3:
Genius:
  • Washing Mach... Master 1,482 Answers
  • Posted on Feb 09, 2010
Gerry Harvey
Level 3:
Genius:
Answers
1482
Questions
0
Helped
379184
Points
4533
If its also not spinning or pumping out ..Sounds like the door interlock switch....
1helpful
Zanussi jetsystem zwf1631w error code20
Hi
This error code indicates a water pressure concern. Not enough water is getting to the machine in the proper time frame. There are a number of reasons this may happen and some of them can be extremely easy and quick to fix.
One of the easiest solutions is to check both the hot and cold water shut-off valves and confirm that they are open as far as they will go. Perhaps the last time someone check the hoses, or moved the washing machine the handle was left off or only partially opened and the F20 error code will appear. Make sure to check both the hot and cold water faucets.
The second option is that you may have a defective hose. If the host has become kinked or in some other fashion damaged it may be stopping or slowing water.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
2answers
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
Hi, ive got a zanussi jetsystem excel 1250 FJS-1397W model washing machine. it wont empty the water after a wash. could you tell me what to try or whats wrong? thank you, fiona
Locate and clean filter, which should be at bottom front right of washer, behind drop down or push down flap.
Unscrew anti-clockwise to remove and clean.
3helpful
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
6helpful
2answers
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
4helpful
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Zanussi Jetsystem
scrub above the soap tray to make sure the holes are clear if they are you may have a system where the fab condit water valve is u/s.
1helpful
2answers
Jetsystem not working
It sound like an clogged inlet water line issue. Check for clean filters and inleat water valve.
Top Washing Machines Experts
john h
